Loe629 Posted May 18, 2017 Posted May 18, 2017 Hi I'm a newbie and I have a problem that I don't know how to fix I need some advice Anyone
slice Posted May 18, 2017 Posted May 18, 2017 Welcome to the YOC. Might help if you said what the problem was..!
Loe629 Posted May 18, 2017 Author Posted May 18, 2017 I had a pin hole in my frame where the oil cap and the frame meet I packed it with Jb weld and now it's like it's too much pressure in the frame oil is coming out under the cap oozing
Moderator Cynic Posted May 18, 2017 Moderator Posted May 18, 2017 Either you have overfilled it, the breather is blocked or your piston rings are toast. Written in order of easiest fixed.
Loe629 Posted May 18, 2017 Author Posted May 18, 2017 Let me know wat u think I don't think I over filled it but I haven't checked my breather I'll do in like 30 mins be back with u
jjennyville Posted May 21, 2017 Posted May 21, 2017 Waiting for the answer, have you checked yr breather
Moderator Cynic Posted May 21, 2017 Moderator Posted May 21, 2017 Generally means we were right. likely not hear a peep till the next issue.
