May 18, 20179 yr Hi I'm a newbie and I have a problem that I don't know how to fix I need some advice Anyone
May 18, 20179 yr Author I had a pin hole in my frame where the oil cap and the frame meet I packed it with Jb weld and now it's like it's too much pressure in the frame oil is coming out under the cap oozing
May 18, 20179 yr Moderator Either you have overfilled it, the breather is blocked or your piston rings are toast. Written in order of easiest fixed.
May 18, 20179 yr Author Let me know wat u think I don't think I over filled it but I haven't checked my breather I'll do in like 30 mins be back with u
May 21, 20179 yr Moderator Generally means we were right. likely not hear a peep till the next issue.
