I just bought aftermarket horn for my yamaha sr125 to replace old, rusty, squeaking horn. I have two questions. If i connect it wrongly can i blow a fuse or it will be ok and i will only need to rotate the plug on the horn? And second question how to recognize earth and positive on the horn and on the wires? Picture of the horn attached.
I may be wrong, but I don't think it matters ?
If the two are identical just wire them up the same, shouldn't blow a fuse I don't think
Sent from my C5303 using Tapatalk
It does not matter.
Sent from my SM-N910G using Tapatalk
Yep as Andrew said not important, I think you'll fine that the horn is earthed through the mounting.
