April 1, 20179 yr Anyone got any recommendations or tips to completly remove the paint from my tank, I plan to repaint after a satin black
April 1, 20179 yr In my view, modern paint strippers are piss poor. Likely to be quicker and less messy sanding it off
April 1, 20179 yr Author 22 minutes ago, neversaydie said: In my view, modern paint strippers are piss poor. Likely to be quicker and less messy sanding it off Cool I'll give that a whirl, cheers
April 2, 20179 yr Hi Spike . Unless the tank has rust there's no need to go back to the metal , esp if you'll be painting it black . Just "flatten" the gloss on the top layer back with some fine wet and dry paper . Depending on the condition/colour of the tank you mightn't even need primer . Simonis Hard Black is a good all round paint and it's pretty cheap .
