xtz660 low speed running problems
Hello, my xtz660 seems to be getting 'lumpier' to ride at low speeds (25 - 40 mph). Its fine at higher speeds ! I have no manual for the bike, so need some help !
Also, decided to fit a new plug, just in case that was a simpe cure, but cannot get any of my spanners to get under the frame. Any idesa on both items, much appreciated.
sounds like a carb problem. crud from the tanks (use an in line petrol filter) or blocked air filter or fuel tap.
Not sure, but looking at a photo of the bike, you will have to take the tank off
Hope that helps
