April 21, 20178 yr Author Well ordered a plus 2 17t if it fits and a plus 1 16t as well. Arriving tomorrow so I can check shaft at the same time. Will post on results
April 23, 20178 yr Author First ride out today. I did tension chain to 50 mm when fitted new as of Haynes manual (Sorry thinking of the bandit 1200n) Its the rear sprocket that has worn teeth. Tensioned again sprockets not arrived yet. I expect tomorrow Oh it broke down at sainsburys cheadle on the roundabout. Luckily it was out of super unleaded! Fuel tap on reserve setting now leaks as well. It was fine in November when I last rode it! Good to be on him again.
April 23, 20178 yr Moderator wonder how many there are in our area, I know of only 3 yours mine and one in Dukinfield
April 23, 20178 yr Author I saw one on bonis hall lane on my way to macc about 3/4 yrs ago. Was a couple of riders with him. Thats the only one ive ever seen
April 24, 20178 yr Author They have arrived. Not a lot of clearance between swingarm roller and sprocket
April 25, 20178 yr Author Well the 17 tooth is fitted. It just fits. The 15 is here which I had to get the windy gun to remove It now clears the top of the swingarm chain roller with the 17 tooth just.
April 28, 20178 yr Author Well went out for a first blast today since sprocket change. All I can say is wow! I can keep the front wheel on the ground and where I would have been in sixth gear from the lights I am still in 3rd with the 17t front sprocket. Gear changes are about 6-8 seconds apart. The swingarm roller seal guard is not touching the chain anymore and is smoother ride. That was brand new when fitted and has been busy looking at the grooves in it. No play or oil leaks detected in shaft. Probably if I adjusted the rear shock to softer it would have given the same effect. Feel like it's an Rd200 but with knobblies on. Dont forget im 1.50 oversize and energy induction fitted too. It now feels like I could ride it for longer distances without fighting it all the time.
May 2, 20178 yr Author Revs to speed in top gear. 30 mph is 3000 rpm, 50 mph 5000rpm. Can hold it on an incline under the powerband. 90 is 9000 rpm.
May 2, 20178 yr So I assume it wasn't you who hammered the shit out of that poor bloody nut holding the front sprocket on! They got no spanners where you bought this from Simon? Just cold chisels and a lump hammer engineering.
May 2, 20178 yr Author Schoolboy no tools 1970s mechanics! They did the same with the steering head nut. The guy who bought it brand new (now passed away) forgot to put 2 stroke in it. It sat since 1980 after a rebore in Ashton which the guy didnt chamfer the ports. Rings broke after 15 mins running. Because the sprocket nut was original I thought I would keep it.
