April 9, 20179 yr Great engines, just be careful of sprag clutch issues. Sent from my E6553 using Tapatalk
April 10, 20179 yr As above the Triumph sprag clutch can be a concern, don't worry to much about it tho as long as it runs and drives ok you should be fine for a few weeks. And as for "the wife" flowers mate, lots of flowers, oh and cakes or anything with chocolate on it and you'll be fine. Ps this is what to listen out for when you try the bike out, if the sprag has failed or on the way out you get this noise.
April 10, 20179 yr Moderator usually because the battery doesn't give enough amps to the starter motor, so don't let it labour. keep the battery well charged
April 11, 20179 yr No Drewpy this actually is a broken sprag clutch mate, even if they do go it should cost no more than £160 for a replacement and about 4 hours to swap out. Plus if you do replace them with a new updated one they are slightly larger and less likely to go bang!
April 11, 20179 yr Author ended up buying a bmw r850r the triumph was a bit top heavy for me. I am used to cruisers so the r850 weight was lower down n i Think it'll be easier to manage. I still class myself as a beginner so I went with my head rather than my heart.
April 11, 20179 yr Nice one mate, good little bikes and BMW reliability. Get yours fixed now and bang this one back one ebay when your up and running. Just one thing tho, this isn't usually a £600 bag of bolts from the net they usually cost a couple of grand don't they?
April 11, 20179 yr Author yeah man couple of k. I'm gonna use it as an every day bike cause driving 60 miles + a day on my dragster is killing the chrome so I'll keep the dragster polished and looking good for dry days and use the bmw in the rain. n it means when I do go to sell either I'll get most of my money back cause they won't have rusted much
