Fuel pump
Keith Higgins
This post is 2858 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
If it's like a buzzing/rrrrtttttttttttttttttttttttt that slows/stops after a couple of seconds, then yes it's just priming.
If it's a slow click-click-click like spokey-dokeys, then possibly something else and possibly a problem...
Link to comment
Share on other sites
1 hour ago, Keith Higgins said:
I have a 2001 fazer 600 when I turn the key on then the red switch on i can hear a clicking noise coming from the pump is this normal or is it the pump priming?
 When I turn the key it was clicking for a few seconds  yesterday it stop clicking and the bike is pulling back like it's getting no fuel  would it be the pump
Link to comment
Might well be the pump, yes.
If it usually clicks/buzzes, then it's usually working fine. If it doesn't make noise and the bike runs fine, then I'd assume it's already primed.
If it doesn't make any noise and the bike runs badly, then it could just be the cold or your points may need servicing. If you're happy taking things apart, it's likely just a case of lightly sanding the point surfaces.
Link to comment
Yes, but bear in mind this is an internet diagnosis only, based on what info you posted. Could still be several other things.
You haven't done the silly and left the fuel tap off or anything, have you?
Link to comment
cor your posh, it was cards and sellotape round ours.
Link to comment
Sellotape, we had to make do with cards and a peg.
Link to comment
Not really - A pack of Cornflakes cost less than Sellotape and the Spokey Dokeys came free in the box!
Link to comment
Your assuming we bought the tape and the card.
Link to comment
Some fuel pumps have filters .  my mate found a  brillo pad in fuel pump .  ;)
Spokey"s , we used  lolly pop stick,:biggrinbounce:
Link to comment
Carb'ed yams with electric fuel pumps usually have a fuel filter after the pump. ~It is worth inspecting this and replacing if it is blocked. Any generic inline filter will do (a motor factor will have something close on the shelf for less than a fiver), I replace them every couple of years as a routine. Also the fuel entry to the carbs may have a filter 'sock' inside the inlet pipe. It is worth removing and cleaning.
  • Like 2
Link to comment
Nah, too warm down here for ice....:ssst:
  • Like 1
Link to comment
  • Recently Browsing
