January 22, 20179 yr Need help first Yamaha Chappy no spark how to set points. Don't have a manual. Thanks
January 22, 20179 yr Hi steve", you need feeler gauge -and the correct Gap, as your timing is set this way too, . member "Wild foamy] on here has a chappy, and info,
January 23, 20179 yr Author I got a gauge but no idea on how to set the timing. I work on Honda Z50s but, I don't see any marking on the flywheel to set them. I have no info on how to work on a Yamaha. Thanks
January 24, 20179 yr Eh all I got is a parts catalog for mine, I can measure mine up when I'm back at work if that's any good to you?
