January 20, 20179 yr Moderator jack you really do need to get on top of this picture posting malarkey
January 20, 20179 yr Author My phone won't let me post photos so have to copy and paste I'll try agin tomorrow in the computer
January 20, 20179 yr 1 hour ago, Airhead said: jack you really do need to get on top of this picture posting malarkey I"l let you know" no Malarkey-ing has been done, [ Flyday "]. pmsl,, at that ,,
January 21, 20179 yr Moderator 15 hours ago, jackpollard6 said: Hello mate I looked my stator is actually 5 wires Nope, misunderstanding, you have 6 wires coming from the engine. One of those, the blue one being the neutral light, the rest from the mag. There are 6 wires at that cdi and the older cdi has 7 wires, an extra red. This called 7 wire. Slightly vicarious use of words calling it a 6wire mag but hey, roman roads are arrowstraight too eh? You 'should have: green/white - Charging/lighting (dc) yellow- Lighting (ac) brown- cdi white/red- Trigger coil black- Earth The second colour is tracer.
January 21, 20179 yr Author Hi mate that's exactly what I've got so I'm just going to buy a second hand original cdi and try that thanks for your help mate!
January 23, 20179 yr Author Sorry I've got one more question what's the output from the stator before i put it back together I won't to check it's all ok I've ordered and manual but taking for ever to come thanks again
January 23, 20179 yr Moderator 1 hour ago, jackpollard6 said: Sorry I've got one more question what's the output from the stator before i put it back together I won't to check it's all ok I've ordered and manual but taking for ever to come thanks again Can you be a bit clearer with that question...how can you check the stator output when it's not together? or are we talking Ohms values here?...hardly output from the stator
January 23, 20179 yr Author Hello yes mate sorry my work colleague was checking it and asked to check the ohms from the stator he said you could do it to see if anything had broken as theres a few split wires which i have fixed now
January 23, 20179 yr Moderator Black probe on a clean ground point Red probe on...... Brown, Meter to 2k Ohms, 300 Ohms for mk2 (Magneto charge coil) White/Red, Meter to 200 Ohms, expect 10 Ohms for mk2 (Magneto pulser coil)
February 18, 20178 yr Author Hello I have one more question I'm buying a new cdi for my bike from Rex's speed shop the bike currently has a six wire cdi but there is 7 wires the spare wire is red from the bikes loom I also have 5 wires coming from my stator but the bike starts and runs now with the cheap 6 wire cdi thanks
February 18, 20178 yr Author Sorry it made sense to me do I need to buy the 7 wire cdi or the 6 wire cdi?
February 18, 20178 yr Moderator it depends entirely on which stator/rotor you have, are there two coils piggy backed or not?
February 19, 20178 yr Author Hello I only have one coil unlike the one in the photo you posted a while back had 2 thanks
February 19, 20178 yr Moderator 6 wire cdi then jack, the red wire in your loom will have no part to play
