Posted January 13, 20178 yr Hi ,,Im just after some advice on a dual load equalizer. I just changed my blinkers over to Led,,yes flashing radically fast, aware I have to install a load equalizer to regulate flashing back to standard and looked for one but that many to pick from so can anyone point me in right direction for the type/configuration I need pls. Old girl is a 2003 Vstar classic. Really appreciate any help, will save me hours trying to figure it out. Thanx in advance
January 13, 20178 yr As far as I know all you have to do is put some resistors in line, that should have the same effect as using a bulb, however as far as knowing how strong a resistor you should use I'm not sure I'm afraid
January 13, 20178 yr Ohm's law will help you calculate the size of resistor you need. However the easiest option is to change to a solid state flasher relay such as this one: https://www.amazon.co.uk/dp/B002RB4D6M/ref=cm_sw_r_cp_apa_DErEyb9V09W6Y Sent from my E6553 using Tapatalk
January 14, 20178 yr Author Thanks heaps finnerz89,,that seems like a way easier less fussy option,,really appreciate you opening my eyes to an alternative option,,,sometimes we are to close to the problem to think "alternatives. Thanks heaps
