dan28 Posted January 3, 2017 Share Posted January 3, 2017 who on here has ran their loom internally through the frame tubes are there any tips on doing this Link to comment Share on other sites More sharing options...
Moderator drewpy Posted January 4, 2017 Moderator Share Posted January 4, 2017 make sure the wires doen't get chafed and make sure they are wrapped. each hole in frame should have grommets. never done it myself but plenty on other forums like chopper underground Link to comment Share on other sites More sharing options...
dan28 Posted January 4, 2017 Author Share Posted January 4, 2017 thanks I ll take a look on chopper underground I found a few threads on the net from what I ve seen people file the hole an test it by pulling tissue through it when it doesn't tear the tissue its smooth enough obviously the wires are wrapped too I ve not seen anyone use grommets if you use grommets is it possible to get some that have a senseable external diameter I have some here that need a 17mm hole but the hole in the grommet is only about 10mm Link to comment Share on other sites More sharing options...
Moderator drewpy Posted January 5, 2017 Moderator Share Posted January 5, 2017 why not use a U channel trim, that should do it Link to comment Share on other sites More sharing options...
dan28 Posted January 9, 2017 Author Share Posted January 9, 2017 On 05 January 2017 at 7:22 AM, drewpy said: why not use a U channel trim, that should do it thanks drewpy that will work fine an will solve the problem of the wire coming through the grommet nearly horizontal I can use elongated holes with u channel trim an the wires will be vertical along the frame Link to comment Share on other sites More sharing options...
