DT175MX - Square Swingarm Model
Hello all, im still building up "bits" for my basketcase that is my DT an just received a oil reservoir
Only is, i dont know if its the correct type for mine?
My bike is a Y2K type.
The oil bottle is the triangular type
exactly like this
is this correct for my bike?
thanks
Yes, if your building a basket case up buying parts from various places to get a complete bike unless your really bothered the later spec is the one to go for as parts will be relatively easier to find as it was made in greater numbers.
Secondly, Y2k? Huh.
The chassis numbers for 175's with a single shock start 2K4 its the numbers after that tell you the model code for parts:-
-000101 onwards are 2K4 (1978)
-010101 onwards are 2X2 (78-79) and similar (near identical) to the 2K4 both having the round sw arm and the above oil tank.
-020101 onwards are 4J4 (80-84ish) look the same excepting the now square sw arm and a different rear shock. More importantly the rear mudguard section at the heart of the bike mounting the air filter, battery, voltage reg (moved on the 4J4) and the oil tank is different. The ignition also has a different stator and cdi with an extra wire in the loom..
Sorry my mistake, I meant mine is a 2K4.
Balls, being that mine is the later box section swingarm, would that mean the oil reservoir isn't for mine.
Oil tanks seem to be like hens teeth, why are they so rare? I dont think I have actually seen any other type other then the one i just bought
Although there seems to be a few bits n' bobs in Germany for the later bikes (2K4)
thanks
Never thought about looking in French eBay.
cheers Airhead, I will wait for confirmation that it fits then contact them
thanks
Yep thats the one.
