DT175 Engine Lift
Mark Wheeler
This post is 2906 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all. New two Jap Bikes with TD175 1975 USA Import. A joy to work on until came to get Engine out. Removed 3 Bolts as per instruction, however Engine just rattles around each Location Lug area and will not come out. No visible damage to Frame. Engine will just not come out, I have tried to lever it out but could do with a bit of step by step advice. Cheers.
Airhead
While taking some pictures I suddenly realised that the Bar holding the Footrests was not actually part of the Frame, and as soon as I unfastened the fixing Screws and pushed the Bar forward the Engine lifted out sweet as a nut.
Like they say you live and learn.
Thanks for advice anyway.
Cheers
Mark
dide  was noas t acESuccess. I hadn't noticed that the Foo
