Replacing coil connector
Ok so I have a dodgy coil on my xv125 ,  I ordered a compatible one but it has 2 6mm male spade terminals instead of a 6mm and a 4mm I think it is I need, so question is,
is it just a case of cutting old female spade connector off the wire and putting a larger  one on it and it will be good to go.
Sounds about right, just chop off the ones that don't fit and solder on some new ones, Just a suggestion tho, make sure, if you can, to use the ones with a plastic sleeve to keep it as water tight as you can.
Further to this does anyone know the primary and secondary resistance for the xv125 coils
Dont have the info for the xv125, but the xvs125 is:
Primary: 3.4 - 4.8 ohms @ 20 degrees C
Secondary: 10,400 - 16,800 @ 20 degrees C
Cant imagine that the xv would differ enough from those figures
