Posted May 31, 200619 yr So I just bought my Yamaha VStar 650 classic. Rode on it for a while and decided to upgrade the exhaust. Went to a place where the guy is very knowledgeable and lots of friends recommended this place. Well I bought a set of vance and hines exhaust pipes for the bike. They sound great. When I give it gas it goes fine, when I let go of the gas is when it starts to backfire. I've heard that jetting should be adjusted after upgrading the exhaust pipes and that it doesn't. I haven't jetted since I put the pipes on. I haven't called the guy either. I will though in the morning. This backfiring has been going on for about 2 weeks now. Just curious if anyone has any tips on this. Haven't done a search yet on here but any advice is welcome. Thanks Joe
May 31, 200619 yr Backfiring is usually caused by excess fuel passing into the pipes and then igniting, or an air leak which assists the normal exhaust gases to ignite in the pipe, or a combination of the two. So, if I were you I would first of all chat with the guy who supplied the pipes to see if any rejetting is required which I would have thought was most likely. If not, check the seal of the pipes at the head for any leaks. Cheers, Andy
