DT 125r Rebuild. HELP
Hi there
Can anyone please help. just rebuilt a 1988 dt 125r and can find nowhere to attach the 2 stroke oil pipe to.My carb does not have a connection at the front (like in the hanyes manual) and also theres nothing on the manifold between the carb and engine to conect it to.
  • 3 months later...
Hi there
Look for a bolt on the side of the cylinder. I'm not sure for that year,the older bikes had a banjo bolt which was a bolt with a hollow center and two holes on the sides . This bolt went through a circular end fitting on the oil line and the whole thing screwed to the side of the cylinder. There were fiber washers on either side of the circular fitting to prevent leaks.
Good luck.
Opinyun
