Thanks for the reply.
I've bought a block and top end casing for my current engine so I'm going to attempt the rebuild myself! Here's hoping I don't screw it up.
Hopefully with lots of photos, taking my time and support from the service manual / support from this forum I'll succeed!!
Thanks for all the help!
i'm just doing the valves ATM, the little shims are a pain and need to take the cams out too :(
One thing I noticed, the pounding on the inlet journals peens the alloy slightly, check that you have 3mm oil holes on the gallery (one had closed up to 2mm) and I had to file away the edges just to get the buckets out.
they are cracking engines though
I'm hoping the internals are okay! Hopefully I can leave the valves etc alone and bolt them straight in to the new head/block! However I'll be inspecting it thoroughly.
Are there any pics available that your aware of of the internals?
Goodluck with the valves though.. sounds like a fun job. I'm sure I'll find out in a week when my parts arrive!
thanks
