Posted October 19, 20169 yr Can you get a replacement / copy of the Yamaha label that is attached to the frame headstock
October 19, 20169 yr I looked for one for my project, no luck! A dealer may be able to get one or yamaha UK, however that's going to cost a lot Sent from my E6553 using Tapatalk
October 19, 20169 yr Author My frame is ready for powder coating. I just don't want to destroy this label which still exists. One option could be using high temp tape but this would not survive the bead blasting ?
October 19, 20169 yr Can't you just mask off the label like you would for sandblasting? Just using different materials for each procedure? I would think you'd mask for sandblasting and then redo it for powder coating, but I've never powder coated anything before
October 20, 20169 yr Best bet is to try a hot air gun and remove it, then glue back on when it's been coated. Sent from my E6553 using Tapatalk
October 20, 20169 yr Moderator is it those E11 type stickers? stuff like that is repopped for the classic RD's LC's etc
October 20, 20169 yr Author Yes I've got a hot air gun also small steamer. When you say "repopped" does that mean they are available from somewhere ?
October 20, 20169 yr Moderator 31 minutes ago, Alan.Tdm said: Yes I've got a hot air gun also small steamer. When you say "repopped" does that mean they are available from somewhere ? depends if its an E11 type sticker
October 21, 20169 yr Personally, i think powder coating on frames is way overrated, its way too thick, cannot be touched up, and is a pain in the arse to tap&die all the threads or find nuts and bolts for them. All my restos now get sprayed the ''old fashioned way, here its no more expensive than powder-coating, and you get to save vin labels etc and you can still see the stamped vin #s, which seems to virtually disseapper when powder-coated.
October 21, 20169 yr Moderator 4 hours ago, anyoldiron said: Personally, i think powder coating on frames is way overrated, its way too thick, cannot be touched up, and is a pain in the arse to tap&die all the threads or find nuts and bolts for them. All my restos now get sprayed the ''old fashioned way, here its no more expensive than powder-coating, and you get to save vin labels etc and you can still see the stamped vin #s, which seems to virtually disseapper when powder-coated. I disagree, I've just touched up my wheels on the FZ when I changed disks I get the RAL number off the powder coater. Paint in the UK is very expensive compared to powder coating (Paint is labour intensive). A specialist powder coater won't lay it on too thick and preserves the stamping.
October 21, 20169 yr Sorry Drewpy but have to agree with Anyoldiron on this, powder coat is a pain in the arse when it comes to torque settings, I did my XJ with a gun and it came up really nice, but your right about the cost of paint, My paint was £90 a half litre and then there was the cost of under coat and clear coat to consider, total was about £190 but had the satisfaction of doing it myself. Mind you tho it did have a total of about 20 light coats of paint when I finished it.
October 21, 20169 yr Author Thanks for all the info. I've found a company up in Mansfield that re produce these Headstock labels. The company I'm using for the Powder coat have reassured me regarding any punched markings on the frame.
October 21, 20169 yr I think it depends on who does the powder coat, I had my frame done at a steelwork company and it was way too thick in places. Plus I lost my frame number etc. However the guy that did my engine cases is a bike nut so I'll be going to him from now on Sent from my E6553 using Tapatalk
October 21, 20168 yr Moderator triple s in bingley are the market leaders in bike powder coating. I use Ashton powder coat now as they are a professional comany and even plug the threads. A few guys at the meet last night had the chrome effect done on their wheels and it looked great
