January 1, 20215 yr Moderator Yes they are just a taper fit, if you get a grip and wiggle them they pull out
January 2, 20215 yr Author On 12/24/2020 at 5:02 AM, NE0 said: Hi there, I recall it wasn't easy putting on the hose inside the oil pump housing, however, i kept a photo record so here it is and the method i used to install it. https://flic.kr/p/2kjYRbX I was hoping the photo would show instead of a link, but never mind, clearly i did something wrong! I followed Drewpy's post on the help page using embedded bb code, then part of it, all to no avail. so I gave up and ended up just putting the link in above. Cheers for confirming the fittings can be removed.
