1980-G DT175MX 2-Stroke Oil Leak (US Model)
This post is 1422 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
On 12/24/2020 at 5:02 AM, NE0 said:
Hi there, I recall it wasn't easy putting on the hose inside the oil pump housing, however, i kept a photo record so here it is and the method i used to install it.
https://flic.kr/p/2kjYRbX
I was hoping the photo would show instead of a link, but never mind, clearly i did something wrong!
I followed Drewpy's post on the help page using embedded bb code, then part of it, all to no avail. so I gave up and ended up just putting the link in above.
Cheers for confirming the fittings can be removed.
