Posted October 13, 20169 yr I have a couple of different questions 1 my bike came with a lowering link does anyone have an oem one to make the bike go back to stock height.. 2 I want to switch over my front suspension can I do a 09 front end conversion to my 04?
October 13, 20169 yr are the lowering links that are fitted adjustable? Perhaps they could be changed to stock height/near stock height. Why change the front end? Do you mean only the forks? Diameters are 2mm difference - but you can make anything work if you want it to...
October 13, 20169 yr Author I don't think they are adjustable and I want to do an inverted fork conversion Sent from my SM-G925P using Tapatalk
October 13, 20169 yr Perhaps there are aftermarket forks that would fit straight out of the box with less hassle? I'm not really sure if there would be any other issue with a switch to Upside-down forks. - I assume that is where the difference in diameter comes from though....
October 13, 20169 yr I'd been inclined to look on ebay for standard dogbones, there are always some for sale search for linkage or links though. As for fitting a later model suspension, is it worth the hassle? you'd be better off fettling the suspension you have than fitting the suspension from a newer model. I have 2 bikes with USD forks and they aren't massively better than RWU forks, the reduction in unsprung weight can be achieved more readily elsewhere. Why not get them rebuilt (Or do it yourself) and fit racetech emulators if they are RWU forks? that'll give almost race levels of damping. Don't make a load of agro for yourself, k.i.s
