Fazer 1000 French import.....
My FZS 1000 is a French import. The importer tells me it is not restricted. How can I tell if this is true or not without using a dyno?
How easy is it to derestrict French import Fazer 1000's?
Thanks!
Nomad
Thanks!
Nomad
Nomad. Easy to check. Restriction is by large plastic spacers in the top of the carbs to prevent them opening fully. It will lose you 30 bhp minimum. Take the top off the carbs to check. You ought to visit www.foc-u.co.uk to learn all there is about Fazer thous.
