Spare key required for ybr125
dandanthepizzaman
This post is 2901 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
try another locksmiths someone should cut you one, I find the old school guys can't be arsed with foreign locks for whatever reason.
As above if one won't do it find someone else but is it just a straight key or one of those with a chip in it? If it has a chip then your going to have to get it from a specialist, my car has one of these and they are £90 a pop!
might be that the blanks are special, I had to buy a blank for my key cutter to use as he doesn't get those in any quantity
http://www.ebay.co.uk/itm/Motorcycle-MOTORBIKE-Scooter-IGNITION-key-blank-with-blade-SUITABLE-Yamaha-M12-/181757444885?hash=item2a51968315:g:qA8AAOSwQItUFvf8
check the "scallops" on yours to see if they match the blank ones
Yeah it's just a standard key so should be available from any good locksmith, there's a chain of key cutters called "TIMPSON" they cut all my keys and costs around £4 a key.
Thompson's are expensive ,
They will not use blanks supplied by yourself, they only use there own ,
Go to a paki key cutters ,they are usually a lot cheaper.
And that key in the photo isn't chipped so £2.50p should get you a new key.
Yup. Timpsons are EXPENSIVE. They were also the only place in Brighton (within walking distance from work) that did bike keys. it was £8! 2 for £12. Jeeezz it took the guy about 30 secs to do each one. What a rip off. Of course now I have spares I'm NEVER going to lose the original. Thanks for the advice peeps.
I paid £12 for two of them, thought it was reasonable. You have to remember that cutting a key is a very skilled job, requires very specific machinery, and add on the price of the key blank. You have two options, £6 per key, or pushing your bike home with the steering lock on.
  • Like 2
