Throttle cable
I need to replace the throttle cable on my DT125LC1. Some suppliers list a "pull" only one. Can anyone give more detail on this ? The cable also needs to work the injection pump to vie a slave cable.
It seems that "pull" throttle cables rely on the carb return spring to de throttle. The modern system is the pull / push which is safer ?
Single cable at the twist grip. Hence the 'pull' only.
