Posted September 22, 20168 yr Dose any body out there no were I can get the gearbox main shaft for my DT175 engine number is 1G1 -103301 It the shaft with idler gear one end and drive sprocket the other. Mine is bent as the idler gear has come lose and eaten ists washer and clip. Thanks Graeme
September 22, 20168 yr Moderator 4 minutes ago, blackhat250 said: Ebay"s the best bet Graeme,  unless Cynic has a spare, Its a twinshock John...are they the same shafts as the MX's?
September 22, 20168 yr I think the splines for sprockets are different too, [ twinshocks are fine spline]
September 24, 20168 yr Author Hi there thanks for you thoughts no on eBay at present like hens teeth No heard of cynic. Graeme
