dt 175 clutch
Hi all, i have a 1976 dt175 that i am in the process of renovating and having a little trouble with the clutch i have replaced the plates and springs and done the adjustments but can't get it to disengage when the clutch lever is pulled in the plates do not move have i tightened the springs too tight or could it be another issue the cable is fine.thank you.
Little ball bearing present?
Ball bearing +1
