Bullet to Spade Connector
martynball
This post is 2988 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey, brought some indicators for my bike, and a tail tidy. They both use bullet connectors for power, however my bike has got the block with spade connectors inside, shop down the road sells converters, but like £5 for 2, anyone know what they are called or if I can get them on ebay?
I would replace the bullets with the terminal blades and use the original housing.
there is a tang on the blades to locate in the housing, use a jewlers type flat screwdriver to bend it back inside the terminal block and they just pull out
12 minutes ago, martynball said:
Well it's the indicators and number plate light, how do i find what connector I need as there are a lot of different sizes isnt there
measure the spades, usually 6.3mm for jap stuff
