Bullet to Spade Connector
Hey, brought some indicators for my bike, and a tail tidy. They both use bullet connectors for power, however my bike has got the block with spade connectors inside, shop down the road sells converters, but like £5 for 2, anyone know what they are called or if I can get them on ebay?
I would replace the bullets with the terminal blades and use the original housing.
there is a tang on the blades to locate in the housing, use a jewlers type flat screwdriver to bend it back inside the terminal block and they just pull out
Well it's the indicators and number plate light, how do i find what connector I need as there are a lot of different sizes isnt there
measure the spades, usually 6.3mm for jap stuff
Turns out the spades in the terminals where 2mm wide! Looked everywhere for the original connectors, had no luck. Might be worth replacing them with more widely used block connectors, so similar ones.
Jap spades on flea-bay,,,
