August 24, 20169 yr I want to fit this carb to the dt engine but do I need to change all the jets first it had a 142 main jet fitted I was told to use a 170 on the dt engine I m unsure if I should also change the pilot jet it has a 45 fitted an do I also need to change the atomiser jet too the one fitted is 266OGk
August 25, 20169 yr Whew" dan, that's a grey area, it suck it and see really , I would fit a TTO temp sensor on the spark plug, so you know whats happening, I did , on my 400. its been a godsend, 500 degree F. is the terminal temp for 2 strokes, , if you get it about 300- 400. YOU KNOW YOUR SAFE,
