hi anyone know if 1994 Yamaha 600 diversion centre stand will fit the 1999  cheers
Only sure way to tell is measure it but on my XJ I found 4 from other bikes in the range that would fit! Typical Yam method is "is it in the bin?" use that then! So most probably the one your looking at will fit.
since that model range was 92 to 04 i don't see why not, it's the same frame.
tell you who will know http://xjrider.com/
