August 14, 20169 yr Hi, after 18 years in my garage I've decided to sell my beautiful bike. Starts every time and brake and indicator lights work. New battery installed but can't get the side and head lights to work. I believe they are supposed to work when the engine is running? The dash blue light (high beam indicator) not working so clerarly an issue which is beyond my knowledge. Could it be the regulator or coil? Checked all cables for cracks etc. Any help appreciated. Thanks Keith
August 14, 20169 yr Moderator do you have to turn the key to position 2 to gat the light working, as you do for it's predecessor the DTMX ?
August 15, 20169 yr Author No to tail light. Tail break light works when brake pressed though. I'm really thinking this is a regulator/rectifier issue. Cant think what else it could be?
August 15, 20169 yr Moderator Is the battery ok. If the regulators gone it will be fizzing like mad. Otherwise the rectifier would be possible but i think the first job is checking the bulbs then cleaning the light switch.
August 15, 20169 yr Author Batt is new, everything clean. Think I'll look for new or used rectifie. Thanks for help.
August 15, 20169 yr Author I've seen the coil but perhaps over looked that option, will investigate cheers
November 14, 20169 yr hi I'm looking for some help with my dt 125 lc with the A,F setting as she wont idle thank u
