August 14, 20169 yr Hi any one tell me how to wire neutral light on Yamaha 600 diversion 1999 just bought the bike and someone has done away with it all together thanks
August 14, 20169 yr Hi Ronnie ", the usual neutral light set-up, is, sky blue wire, [ found behind sprocket cover], , take a look and see if tis still there, . it works by earthing [ switch on shift drum,] .
August 14, 20169 yr Author There's nothing there I bought sensor but can't find wires to conect to bought workshop manual but no pictures of it
August 14, 20169 yr Has to be, as the shift drum, rotates , and neutral detent plunger, slips into the biggest indent on drum[ neutral] this earths switch, and lights on dash,..
August 14, 20169 yr Author There's nothing there I bought sensor they have changed clocks and all tryed turning in to street fighter
August 15, 20169 yr Author Fitted new sensor not sure where to put blue wire or green plug with 2 wires tryed . Putting photos up won't let me
August 16, 20169 yr Author Right found the wires can any 1 tell me what colour of wires up at the clocks is for the neutral light as none of them have connection on them they have all been chopped thanks
