Posted August 13, 20169 yr Hi all I've just bought a 1981 xs 250 that's been restored. And I plan to take it around Spain next year with a few mates. Sounds fun eh. But I just can't belI've how slow this bike is?? 65 mph max!!. Have they always been this slow or is something wrong. She starts off the button and runs sweet. Just NO power at all. Please help!!
August 13, 20169 yr Moderator :welcome:, yep they are a heavy bike due to more meat in the engine. 75 i think is the top end if its igntion setup and with clean carbs
August 13, 20169 yr Author I'm kinda thinking I'm gonna be the back marker of the group now. The others have bought TDRS and TZRS. How about I do the valves and Polish the ports. May change the coils to. We did a similar sort of trip a few years ago on C90s and it was great. No problems at all. We've only just got back from driving a tennis ball covered limo around Europe. 10 countries in 10 days. It's also for sale if you're interested. Have a look on ebay. Or our Facebook page "Balls out limo tour"
August 13, 20169 yr Ha " ANDY " yer mad,,, think I saw your trips somewhere,[ online] , mind yourbody weight is gonna knock a bit off the 250"s performance,
August 13, 20169 yr Author cheers black hat. i am the larger one of the group. i hope i can tinker with it just to get some small improvements, i ideas??? wanna buy a limo??
August 13, 20169 yr I would drop 1 tooth off the front sprocket, . it will pull better, . I would leave engine, you need reliability , .. maybe electronic , ignition "
August 14, 20169 yr Moderator try xs400.com ( I'm on there too) there's loads of info for ya. I'd recommend getting a 400 engine (needs cards too) it'll fit right in and can easily keep up. I did 70 -80 all the way back from NW200 and she never missed a beat If your interested the full SP here
August 15, 20169 yr My first bike was a 81 xs250 and it could do over 80 mind I was only about 7 stone soaking wet back then
August 16, 20169 yr Moderator Er.. Tortoise and hare time. The 2 bonus points for you will be comfort and range. The TDR250 even stock unless ridden at speeds you xs is capable of will struggle to better 35 to 40mpg. Same for the tzr. Both have stingy tanks too. The tdr seat is cruel and gets hot too. Not to mention that bike is a pain to work on. You will have double the tank range no 2stroke to find/carry and much better reliability. Probably the better overall choice if not as sexy.
August 16, 20169 yr Next year is plenty of time to loose a few pounds if you want to go faster - love the limo
August 30, 20169 yr Author thanks for all the replys. been tinkering with the bike today (well just kicking the tyres) i`ve ordered a 14 tooth front sprocket, new rubbers for the carbs. and i`m gonna try and seat the valves and do the ports. my question is how much better will it run with electric ignition?? and which are the best to buy...
August 30, 20169 yr Moderator It will run exactly as it does now with electronic ignition. The plugs will last longer, the bike will be easier to start esp in colder weather and you may gain some high rpm benefits, maybe some more torque and most likely some mpg improvements too, which is just from the engine doing what its supposed too but better, but real world hp you can feel. Nope. Not really. Don't get me wrong it will be a nicer bike to use, and definitely more reliable if you get a reputable kit and fit it well but it wont actually go faster in any real sense, people usually get a 400 engine for that bit.
August 30, 20169 yr Moderator got a Pamco ignition from the states about £120. I believe piranha have revived their ignitions. I also had an ignitor box from gigavolt on the German site. It uses the points but no power goes through them so they last forever
August 30, 20169 yr Author i`ve come across one on yam bitz. "Newtronics" seems to have had good reviews to, but will have to compare them. cheers
September 5, 20169 yr Hi Andy, I toured around Europe in 1978 with a friend on an XS 250 (I rode a KH 250). The 2 week ride, I think, notched up about 3500 miles and the XS and KH both kept up comfortable 75-80 mph speeds on dual carriageways/motorways with no problems - although the XS was often in 5th rather than 6th gear. My KH was always in 5th ........ as it only had 5 gears ! Rather than go for a smaller front sprocket as an early step, why not leave it as it is until you've got the engine sorted - 65mph is not normal for one of those bikes - and then think about it when everything else is right. if you need the higher revs, just keep it in 5th, until you're going downhill - and remember, small engined bikes need "momentum" (just watch Moto3 races), so to keep up with the rest, go as fast as you can down every hill to get a good run up every up-slope :-)
September 7, 20169 yr Author Thanks for that Oldfjman i guy i work with is going to do a compression test on it. so i think i`m going to see what the result of that is before i do any more work on it.
