mr bignal Posted August 10, 2016 Share Posted August 10, 2016 for some reason my haynes manual seems to ignore the fuel tap, leastways i really can't find anything on it - this picture shows the fuel on apparently, thin part of indicator pointing up is reserve but what's prime exactly, something to do with being able to drain the tank please? Link to comment Share on other sites More sharing options...
Malleus Posted August 10, 2016 Share Posted August 10, 2016 Think it can be used to drain the tank as turning it to PRI should allow fuel to drain using gravity rather than vacuum. (apparently it is for when the bike has been standing and carbs are completely dry) 2 Link to comment Share on other sites More sharing options...
Moderator Cynic Posted August 10, 2016 Moderator Share Posted August 10, 2016 Nope. Not standing at all. My TDR will need prime even after a couple of days or you will be kicking for ever till the bike starts. A 3 count on prime. Pull choke and she's away. 3 Link to comment Share on other sites More sharing options...
Noise Posted August 10, 2016 Share Posted August 10, 2016 Ey, as said above, Prime is to fill the carbs up after bike has been standing for any number of time, some might be a day or two some could last weeks. i normally only use the prime if i have had the carbs off and drained them but apart from that i just choke it and fire up. 1 Link to comment Share on other sites More sharing options...
neversaydie Posted August 10, 2016 Share Posted August 10, 2016 and if youve run out of fuel 2 Link to comment Share on other sites More sharing options...
