Yamaha DT125R 2002 - Derestricting
This post is 3027 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello everyone. I tried looking on dtr125.net but it seems to be closed?
I have a 2002 DT125R which is totally standard. It's not done much mileage to be honest so it's not been messed with.
i want to derestrict it but didn't really want to change the tail pipe as I feel that just creates more noise. I am going to use it green laning so like it quite to be honest.  I have read about a reed switch in the speeo and something about cutting a peice off the carb rubber?
basically want I want to get it down to is how can I make a bit more power. Keeping the orginal tail pipe which I think is the best pipe for these bikes.
Any help is appreciated.
I would have thought the last thing you want to do to a dt you want to green lane is de restrict it.
6 hours ago, Retroboy said:
why not?
Green laning needs torque. Clean low rpm manners that allow you to pick your puddle. Then give you a clean progression to solid power when you need it.
You will rarely do more than 15 20 mph.
A peaky derestricted bike would be a pain in the arse.
