Simon46 Posted August 6, 2016 Share Posted August 6, 2016 1 Link to comment Share on other sites More sharing options...
blackhat250 Posted August 6, 2016 Share Posted August 6, 2016 BHP,,, ? Link to comment Share on other sites More sharing options...
Simon46 Posted August 6, 2016 Author Share Posted August 6, 2016 0 at the moment. No spark. Too many safety devices on the throttle. In gear no start cutout and wrist lanyard if you fall out the boat it unplugs and kills ignition. I will be starting by bypassing these to see if motor will run and go from there. Cant be as expensive as a DT175mx field bike resto! S. 2 Link to comment Share on other sites More sharing options...
blackhat250 Posted August 6, 2016 Share Posted August 6, 2016 Yeh, I see why safety counts,, mind that family got chopped, when boat circled them, after the ALL fell out into water, Link to comment Share on other sites More sharing options...
Simon46 Posted August 6, 2016 Author Share Posted August 6, 2016 All safety devices will be reinstated once engine fires. Ive seen prop versus leg. It ain't pretty. 1 Link to comment Share on other sites More sharing options...
Simon46 Posted September 17, 2016 Author Share Posted September 17, 2016 Well depotting the cdi. Should have over 100 volts to the coil. I have 17. Over 15 hrs work to get this far! Link to comment Share on other sites More sharing options...
blackhat250 Posted September 18, 2016 Share Posted September 18, 2016 That's some mess simon, , Link to comment Share on other sites More sharing options...
Sacha Posted September 19, 2016 Share Posted September 19, 2016 Yikes! Link to comment Share on other sites More sharing options...
Moderator drewpy Posted September 19, 2016 Moderator Share Posted September 19, 2016 On 06/08/2016 at 7:02 PM, blackhat250 said: BHP,,, ? 55, it says on the tin I used to have a 45 Mercury with leccy start. nice engine 1 Link to comment Share on other sites More sharing options...
Simon46 Posted September 20, 2016 Author Share Posted September 20, 2016 Its a big engine 2 cyl 2 stroke 800 cc. Cdi had crack through the potting as if something has gone pop and its been left outside for 2 years. Needs replacing anyway. All discrete components internally not a chip in sight. Just scr's caps diodes and resistors. Link to comment Share on other sites More sharing options...
Simon46 Posted November 14, 2016 Author Share Posted November 14, 2016 Well after many hours and also building a dva adapter for multimeter to test cdi reconnected cdi in unpotted format to test and she sparks. connected fuel and on 4th crank she ran. that twin pot two stroke is loud with the exhaust prop out of the water! love it when you fire an engine for the first time. Had to pull plug caps off to stop her though. 5 Link to comment Share on other sites More sharing options...
Moderator Airhead Posted November 14, 2016 Moderator Share Posted November 14, 2016 well done Simon Link to comment Share on other sites More sharing options...
Simon46 Posted December 17, 2016 Author Share Posted December 17, 2016 If you like trance and boats this is how it should go. Look at the 15 ft prop wake! Link to comment Share on other sites More sharing options...
slice Posted December 17, 2016 Share Posted December 17, 2016 Beautiful Simon, I bet the local fishermen just LOVE you! Link to comment Share on other sites More sharing options...
