Yamaha R125 ZYF Bolt Dimensions?
Hey, when I had my bike it was missing a bolt on both sides but in the same place. Not sure what size bolt I need, does anyone here know? I have attached an image showing where the bolts are, need the one I have labelled "Size?".
Also, the hole in the panel doesn't seem to align very good to where the bolt should go, is this because the other bolts I have put in are too tight and needs to wiggle room?
Should just be a standard fairing bolt I think, on the FJR they are chrome or S/S allen key type, if it don't line up then there is something wrong, you need to remove it and find what's happening.
0000-Bolt-Motorcycle-Hardware-Fairing-BoThese are the ones I have on mine.
