Hi there,
Can anyone tell the thread pitch of the bolts that secure the boot from the carbs to the intake manifold? I've had a world of pain with one of these shearing off leaving the bolt stem stuck inside the cylinder head which has been drilled, but still needs to be re-tapped and I don't have a pitch guage to check the pitch to order the right tap.
I know the bolts are metric 10mm.
Any help would be greatly received.
Standard Metric M10 pitch, now you just need to know how long the bolt needs to be.
