Yamaha DT 2002 model struggling for bits
Can't seem to get hold of the following bits
fuel cap seal. Rubber gasket that sits inside the fuel cap
bash plate
fuel tap strainers(small mesh type filters that sit inside the fuel tank and are attached to the tap)
Tried fowlers parts?
that was the first place I tried.
Fuel gasket not avalible separately, fuel strainers I need to buy the whole tap,
bash plate is an aftermarket thing
Sounds about right. As bikes get older they consolidate parts. You want that mesh for my TDR250 you got to buy the whole tank assy.
Tank mesh is easy. Forget it and use an inline filter.
The cap seal should be plenty of pattern seals on e8ay.
Bash plate same. Breakers on e8ay.
I second eBay for the bash plate, got one for mine on there a while back
does anyone know if the tank is still avalible for the blue 2002 model?
