Hello guys.. am new here so hopefully you will have some good knowledge.. I have bought a bit of a project 50cc aerox have been putting it together and when I tighten up the bolt on the end of the crank variator side, it all locks up?.. if I loosen the bolt it all frees up and spins any ideas?.. crank all moved freely before rebuilding head and fitting water pump side everything went smoothly until variator.. please help
Suggest you try YouTube to see if anyone has a similar problem. Seems the rollers are a known fault with these things. Just a suggestion.
