This post is 3073 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi wondered if any one can help please i have just required the above bike, and the starter motor is FUBAR a new one at main agents is £256, ouch, wondered if any one knows of a cheaper alternative, new/secondhand, or evan a faulty one i can disassemble to get the armature out of, had a look on ebay at other yamaha starters and all the bodys look too fat this is the smallest starter i,ve ever came across, all so wondered if there was any maintenance info on the web site please ie oil grade, tyre pressures general when to change this and at what milege, well thanks for taking the time to have a read through cheers
thankyou  for that i wil have a look for that model
You'll also want to get a manual (if you haven't already). That'll give you the general specs and such. :thumb:
on a role here did a bit of googling last night  and found a freebie on line downloadable owners book tells me all i want to know as far as maintenance goes, just need to sort starter motor out and we're good to go, found an old Sukida moped starter motor in my mates shed, striped it down and the insides identical to me yams apart from the end of the shaft is smaller so the search goes on, must be another yamaha or similar  that uses the same internals just looking on fleabay at the moe trying to match
  • 3 weeks later...
Heads up for anyone in the same position as me wanting a starter motor, found a brand new  Yamaha Aerox 100cc Start Motor on fleabay for £23 bangers striped it down and used the centre armature and bushes out of it and have been able to make a good working starter motor, better than £256, was,nt straight forward mind you a little modification here and there but quite easy archivable maybe hours work, time will tell as to how long it lasts
