Posted July 6, 20169 yr Hi I am making some big changes on a 1990 fzs600 that has a electronic speed sensor and I was wondering if someone has found a mechanical speedo drive that fits to use with some vintage speedometers Best regards Örn
July 7, 20169 yr Moderator why not use a GPS speedo, they are very accurate now. Say hello in the new members section first too, we like to know peeps better
July 7, 20169 yr Author 1 hour ago, drewpy said: why not use a GPS speedo, they are very accurate now. Say hello in the new members section first too, we like to know peeps better I am doing cafe look requested by the owner, and he wanted some specific speedo and tacho and the speedo is driven by cable so I need to find a mechanical speedo drive.
July 7, 20169 yr Moderator try an xj600 speedo drive, but it will need some machining on the wheel and lug on the fork to stop it spinning. sure you can retrofit an old speedo with new internals
July 7, 20169 yr Author 11 minutes ago, drewpy said: sure you can retrofit an old speedo with new internals mmm yea why not?
July 8, 20169 yr Author Does someone have the dimensions of a xj600 speedo drive, retainer clutch and driver washer? I cant get any parts here in Iceland and its not fun ordering parts and have to wait 2 weeks to find out that I cant use them
August 12, 20168 yr Author So if someone wants to know what speedo drive to use when converting to an mechanical speedo meter.The answere is a speedo drive and cable from an Yamaha YZF 600 Thundercat.Yamaha 341-25846-00-00 341-25846-00-00 RETAINER,CLUTCHand Yamaha RD Speedometer Drive Washer, 341-25149-00-0 Its a perfect fit. just plug ad play. Have a Nice day.
August 12, 20168 yr Moderator looks great the speedo is the same as the FZ600 and probably most Yams from that period
