Need help identifying an Yamaha Engine
megapt
This post is 2896 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys! I recently bought a non running Raptor 660,
the primary issue would be the starter clutch that should be no problem to resolve, the secondary issue would be the flywheel that was removed by an idiot and bent the "position sensor thingy" as you will be able to see in the pictures.
What I was told was that the engine came from a Tenere (injection model).
The problem is I am not being able to find anything on the web remotely close to this flywheel and I am hoping someone knowledgeable will give me some insight on the matter.
Have you tried here? site_logo.gif http://www.tenere.co.uk/forum/index.php
They seem to have loads of info on your model. Don't know if any of it will help mind! And WTF have they done to that poor bloody bit of metal? looks like it was removed with a sledge hammer!!!!
Also helps if you sign in to the New members section, most folks like you to say Hi in a first post, Thanks.
