Oops " av done it again , DT
Wel it aint summer, , but here  we go , thanks to drewps for the research, [Manchester purchase,]:thumb:
meant to be, with it,  have txt guy,    ,, av got it stripped,  water ingress, been standing long time,   crank solid,  [ handy for removing rotor etc]
its on .50  wiseco piston ,, carb was gummy,  I"v have most parts that are missin , seat base is mint, & foam ,
Seat base ,& standard foam ,
Nice bike Blackhat, so that's your winter project sorted then?
Yeh slice,   gonna see if I can bolt it together before end of season ,  B)
Rainy days = shed time,,   here the engine split,   water ingress ,  and the crank seals were in wrong way round,  mains solid. and the detent plunger w20160614_155739.jpgas in wrong,  [ some one prob thot it was the sump plug ] and stuffed it back in wrong,
crankcase splitter .
And rusty crank ,
Lovely looking bike and it helps if you know what you doing ...... and have the gear ;)
Nice project.
Nice project.
Yeah get yer welder out John :D
