Oops " av done it again , DT
Wel it aint summer, , but here  we go , thanks to drewps for the research, [Manchester purchase,]:thumb:
meant to be, with it,  have txt guy,    ,, av got it stripped,  water ingress, been standing long time,   crank solid,  [ handy for removing rotor etc]
its on .50  wiseco piston ,, carb was gummy,  I"v have most parts that are missin , seat base is mint, & foam ,
Seat base ,& standard foam ,
thought it was running?
Are well, at least the seat is good as that is the hardest thing to repair
Nice bike Blackhat, so that's your winter project sorted then?
Yeh slice,   gonna see if I can bolt it together before end of season ,  B)
Rainy days = shed time,,   here the engine split,   water ingress ,  and the crank seals were in wrong way round,  mains solid. and the detent plunger w20160614_155739.jpgas in wrong,  [ some one prob thot it was the sump plug ] and stuffed it back in wrong,
crankcase splitter .
And rusty crank ,
Lovely looking bike and it helps if you know what you doing ...... and have the gear ;)
Nice project.
Nice project.
Yeah get yer welder out John :D
