In short ( I have posted regarding this bike XJ 600 before - somewhere on the forum :) ) Anyway, before shelling out for a new ECU/EMU, would it be possible to 'hot wire' the bike as I've got no spark?  Of course, if I can get a spark then  I'll be confident in buying a new ECU/EMU. The original ECU was left (as was the Carbs etc in a box that filled up with water!!!) from the bloke that I bought it off I must add looooooollllllllllll. I'm beginning to think that this bike might cost me more than I paid for it £100 - having found out recently that there's a big hole on the swinging arm - exhaust side (Is this a common fault?) but I'm quite handy with an arc welder so that don't bother me. :)
THIS IS HOW IT WORKS,.  the soarse coil generates power, its stored in CDI box,  the trigger [ pulse  coil]  signals to release power from CDI  to  ignition/coil, = spark plug,  ,
correct for a CDI john, but it is TCI which uses coils and is a trigger for them at the correct time
Thanks for your help folks :) I realise now (after sobering up) that it's not like an olde ignitition sys with distributor DOH! BUGGER!
