I am the proud owner of an 1867 Yamaha FZX 750.
Recently I did run is a small issue I cannot seen to get rid of, ore fix.
My Head light went out.
It just happen when I turned on the ignition, light went on but the moment I started the engine, light went out, and is not coming back on.
First I thought it was a bad connection, as some time it comes back on for a short time, but all connections are good, so is the Bulb!
The rear light and indicators are still working, also the instrument lights on the tank are working fine. Just the Head light and instrument lights (speedo and rev counter) are out.
The only one thing I can come up with is a faulty main light relay, but, I looked on the wiring diagram and at part list but no mention of a main light relay!
It shows on the drawing a couple of Relays, Fuel pump, Indicator….
I went to my local Yamaha dealer but he could not help me as it was an older bike and things like that happen??? Go Figure!
So is there anyone out there that can help me with my Black out issue?
Possibly a bad earth. Make sure all the connections are clean. Could also be a loose cable in the headlight plug?
Try running a direct feed from the battery and see if it comes on with that
Hi finnefz89
Thanks for your reply.
I did run a cable from the battery it, light works fine, all the plugs seem to be OK, I clean them all.
all the cables sort of disperse in a cluster, so it is hard to figure out ware thy go.
Because everything ells is working fine, just the head light and the speedo and rev counter,  that's why I though a broken relay.
Broken cable then?
