Posted May 31, 20168 yr Moderator Took the FZ to the dyno today to see if any mods i have done were any good. best run was 60.09hp which is 5hp over stock. Without changing the carbs thats as much as the racers get, so i'm well chuffed interesting that the operator said I could go down a jet size or try and weaken the lower end. the bottom graph is the fuelling and the median line is what we're aiming for. theres a couple of flat lines there where it so rich the dyno can't measure it. I also have a dip in the 5.5k rpm which is about 10 hp worth there. which is where it is rich. the rev counter reads 500 rpm under but as the main gains are around 9 - 9.5 I suppose its not much point going higher up. Â
May 31, 20168 yr tHAT sounds  great, smooth motor, I thought these were bigger than that ,[ power ] Â
June 1, 20168 yr 60hp , not to be sneezed at ! Â Motor sounds real sweet , nice quiet pipe . Â Result !
June 1, 20168 yr Loverly sound! and a good reslut for you! How much was this dyno run if you don't mind me asking? thinking about getting the bandit done to see if i have the right jets in
June 1, 20168 yr Author Moderator 60hp at the wheel is good, motor prob putting out 70 at the crank cost me £30 well worth it, i've dropped the needles one notch and the motor feels a lot better for it. I'm going to leave the main jet at 112.5 as it was slightly lean at 10k rpm.
June 1, 20168 yr Thats a really good price, i thought you was going to say something like £80 haha. I think im going to have to adjust the needles on the bandit, im running 147's
June 1, 20168 yr Author Moderator 2 hours ago, Noise said: Thats a really good price, i thought you was going to say something like £80 haha. I think im going to have to adjust the needles on the bandit, im running 147's just get it on the dyno and stop guessing. the cost mounts though if you want to check what you've done works well. As its not a track bike I'm happy as it is knowing I have it set up in the zone
June 1, 20168 yr I love that sound, kind of amazing how far motorcycles have come since this era of motorcycles, but honestly I'd prefer this over a more modern bike any day of the week. 60hp isn't to be sniffed at.Â
June 2, 20168 yr 13 hours ago, drewpy said: just get it on the dyno and stop guessing. the cost mounts though if you want to check what you've done works well. As its not a track bike I'm happy as it is knowing I have it set up in the zone I have found a dyno just down the road from me so once she's back on the road i'll book her in, she ran great when i took her for the MOT only had a dead spot at about 5k but picked up her knickers at 6k, as you say they will be able to nail down what to set her too.
