ANY YBR 125 RIDERS OUT THERE?!?!?!
Woah there Louis, looks like you've posted the same thread three times, i've taken the other two down and kept this one active hope this helps.
With regards to your stand, might be worth checking it isnt bent or deformed, also have a look from the rear wheel (looking forward) and check that your rear sprocket and chain are in alignment with the front, something is definitely amiss there
Get under there - or turn your bike upside down - and check if your center stand stop rubber (bump stop) is still there.  i.e. if that bike was ever fitted with one.
If you see a bracket in that area pointing downwards (frame or exhaust) with a round hole in the bottom - with nothing in obviously, there's your problem.
And stop shouting ......  ?!?!?!
